Александр Левашов писал(а):
Чем отличается новая 236 от 227? Почему она имеет расширение ZIP, хотя это не ZIP? Надо ли переименовывать перед заливкой? Сохранятся ли настройки, после перепрошивки?
Привет!
А ты где ее взял ?
если на
http://tsd.dlink.com.tw/info.nsf/e24486 ... enDocument
то там английским по синему написано что:
Features Modification
1. Remove AV/IDS function
Bug Fixed
1. Bug fixing: IPSec VPN timeout bug fixed
2. Added back the option to remove an infected attachment file from an infected SMTP email message
3. Added the capability to pass non-HTTP traffic through the HTTP proxy
4. Added support for IPSec NAT -Traversal (NAT -T) draft
5. Improved handling of ICMP messages
6. Improved handling of FTP sessions involving large files
7. Increased the maximum timeout value for RTP/RTCP sessions
8. Support for streaming audio with HTTP antivirus scanning enabled
9. Support for accurate antivirus WELF logging
New features in Release 2.36
1. IPSec VPN improvements
2. Multiple WAN support
3. Policy based NAT
4. H.323 NAT traversal
5. Multiple IP-pools for each interface
6. Configure port forwarding by configuring Virtual IPs
7. Firmware image integrity protection
8. Global user database
9. Logging/monitoring inprovements
10. More pre-defined services
11. User password obfuscation
12. Static NAT
13. Upgrade Note
14. Transparent mode
15. Support for Multiple dial up VPN tunnels
16. Support for traffic shaping on DFL-1000
17. VIP to dynamic external PPPoE address
18. Support for manual MAC address table update, to work with Microsoft cluster
19. Support for "sent=/rcvd=" field in the WELF format log, so that graph
can be drawn in Webtrend
20. Support for limiting the IP pool size
21.support for PPTP MPPE encryption with RADIUS
22. Support for complete range of PPTP/L2TP IP addresses Know Question
23. Web-based administration GUI browser compatibility
24. VPN traffic logging
25. Authentication timeout in transparent mode
26. PPTP/L2TP can only setup 255 IP addresses
27. IP/MAC binding in transparent mode
Ну ребята, давайте читать информацию!?
Насчет Zip - это дейстивтельно архив только битый!!
(смотрим с помощью NC заголовок файла. PK в начале говорит что
это ZIp, далее идет название архивированного файла:
DFL1000-v236-build077.out)
Кто бы сказал буржуям, что нужно его заменить на нормальный??
