По нескольким портам идет blat attack на коммутаторе. По веткам форума смотрел темы, но ничего не помогло. По настройкам на других таких же коммутаторах тоже самое. Подскажите в чем может быть проблема?
222 2023-05-25 11:08:53 INFO(6) Blat Attack is blocked from (IP: Port: 1) 221 2023-05-25 11:07:50 INFO(6) Blat Attack is blocked from (IP: Port: 3) 220 2023-05-25 11:06:40 INFO(6) Blat Attack is blocked from (IP: Port: 1) 218 2023-05-25 11:04:56 INFO(6) Blat Attack is blocked from (IP: Port: 1) 217 2023-05-25 11:04:18 INFO(6) Blat Attack is blocked from (IP: Port: 1) 216 2023-05-25 11:03:01 INFO(6) Blat Attack is blocked from (IP: Port: 1) 215 2023-05-25 11:01:48 INFO(6) Blat Attack is blocked from (IP: Port: 3) 214 2023-05-25 11:00:06 INFO(6) Blat Attack is blocked from (IP: Port: 1) 213 2023-05-25 10:59:21 INFO(6) Blat Attack is blocked from (IP: Port: 1) 212 2023-05-25 10:57:39 INFO(6) Blat Attack is blocked from (IP: Port: 1) 211 2023-05-25 10:56:47 INFO(6) Blat Attack is blocked from (IP: Port: 6) 210 2023-05-25 10:55:39 INFO(6) Blat Attack is blocked from (IP: Port: 6) 209 2023-05-25 10:54:46 INFO(6) Blat Attack is blocked from (IP: Port: 10)
