Alexey Mishenko писал(а):
1. Increment counter for IPv6 L3 discards (v6 packet search failed)
2. Increment counter for packets discarded due to IBP discard or CBP full (run out of packet buffer)
3. Increment counter for packets dropped when ingress port is not in forwarding state (if the port is under STP block/listen state, or under LBD loop)
4. Increment counter for receive policy discard (i.e. DST_DISCARD, SRC_DISCARD,RATE_CONTROL, etc.) (IMPB dropped entries)
5. Increment counter for packets dropped by the Content Aware Engine (ACL drop)
6. Increment counter for multicast (L2 + L3) packets that are dropped (multicast packets search failed)
7. Increment counter for packets dropped due to port bitmap of zero condition (destination port is link down, destination port is in the different VLAN, egress mask was been set)
8. Increment counter for receive VLAN drops (received packets with illegal VLAN tag)
А не как на D-link нельзя посмотреть какие именно пакеты он дропает? Может через CLI или WEB.
