Текущее время: Пн июн 03, 2024 23:05
 Заголовок сообщения: DGS-3620-28SC OSPF Ext-2 Summary
СообщениеДобавлено: Ср дек 05, 2018 14:07
Здравствуйте, пытаюсь суммировать сеть - не получается.
create ipif Vlan172 10.44.172.1/24 Vlan172 state enable
config ipif Vlan172 proxy_arp disable local disable
config ipif Vlan172 dhcpv6_client disable
config ipif Vlan172 dhcpv6_client_pd disable
config ipif_mac_mapping ipif Vlan173 mac_offset 4
create ipif Vlan173 10.44.173.1/24 Vlan173 state enable
config ipif Vlan173 proxy_arp disable local disable
config ipif Vlan173 dhcpv6_client disable
config ipif Vlan173 dhcpv6_client_pd disable
config ipif_mac_mapping ipif Vlan174 mac_offset 5
create ipif Vlan174 10.44.174.1/24 Vlan174 state enable
config ipif Vlan174 proxy_arp disable local disable
config ipif Vlan174 dhcpv6_client disable
config ipif Vlan174 dhcpv6_client_pd disable
config ipif_mac_mapping ipif Vlan175 mac_offset 6
create ipif Vlan175 10.44.175.1/24 Vlan175 state enable
config ipif Vlan175 proxy_arp disable local disable
config ipif Vlan175 dhcpv6_client disable
config ipif Vlan175 dhcpv6_client_pd disable
create route redistribute dst ospf src local mettype 2 metric 20
config ospf ipif Vlan173 area 0.0.0.0 priority 1 hello_interval 10 dead_interval 40
config ospf ipif Vlan173 authentication none metric 1 state disable passive enable
config ospf ipif Vlan173 distribute_list_in none
config ospf ipif Vlan174 area 0.0.0.0 priority 1 hello_interval 10 dead_interval 40
config ospf ipif Vlan174 authentication none metric 1 state disable passive enable
config ospf ipif Vlan174 distribute_list_in none
config ospf ipif Vlan175 area 0.0.0.0 priority 1 hello_interval 10 dead_interval 40
config ospf ipif Vlan175 authentication none metric 1 state disable passive enable
config ospf ipif Vlan175 distribute_list_in none
enable ospf
create ospf aggregation 0.0.0.0 10.44.172.0/22 lsdb_type summary advertise enable
#show ospf lsdb
0.0.0.0 ASExtLink 10.40.0.1 10.44.172.0/24 20 0x80000004
0.0.0.0 ASExtLink 10.40.0.1 10.44.173.0/24 20 0x80000004
0.0.0.0 ASExtLink 10.40.0.1 10.44.174.0/24 20 0x80000004
0.0.0.0 ASExtLink 10.40.0.1 10.44.175.0/24 20 0x80000004
ospf aggregation суммирует ext-2 ?
Заранее спасибо!
