Текущее время: Вт сен 29, 2026 23:57
Начать новую тему Ответить на тему  [ Сообщений: 1373 ]  На страницу Пред.  1 ... 13, 14, 15, 16, 17, 18, 19 ... 92  След.
СообщениеДобавлено: Чт фев 12, 2015 09:30
TretUliy2
по qinq также отписал.
СообщениеДобавлено: Чт фев 12, 2015 18:59
Не сохраняется address-binding.... :(
делаю:
create address_binding ip_mac ipaddress 10.11.12.13 mac_address 50-46-5D-BB-B7-89 port 1
show address_binding ip_mac all
Command: show address_binding ip_mac all
IP Address                              MAC Address       Port
10.11.252.254                           50-46-5D-BB-B7-89 1
Total Entries  : 1
save config
show conf cur
Command: show config current_config
# DGS-1210-28/ME Gigabit Ethernet Switch Configuration
# Firmware: Build 6.11.B044
# Copyright(C) 2010 D-Link Corporation. All rights reserved.
# User Account
create account admin ***
disable password encryption
# Basic
config syslogintimeout 5
config vlan_auto_learn vlanid disable
enable web 80
enable clipaging
config command_prompt default
config serial_port baud_rate 9600
config serial_port auto_logout 10_minutes
# Gratuitous Arp
config gratuitous_arp send ipif_status_up disable
config gratuitous_arp send dup_ip_detected disable
config gratuitous_arp learning disable
config gratuitous_arp send periodically interval 0
# Arp Aging Time
config arp_aging time 5
# FDB Aging Time
config fdb aging_time 300
# Telnet Setting
enable telnet 23
# Vlan
disable asymmetric_vlan
create vlan "test" tag 7
create vlan "test1" tag 15
create vlan "test2" tag 101
create vlan "test3" tag 513
config vlan vlanid 1 advertisement disable
config vlan vlanid 7,15,101,513 delete 1-28
config vlan vlanid 7,15,101,513 add tagged 23-28
config vlan vlanid 7,15,101 add forbidden 1-22
config vlan vlanid 7,15,101,513 advertisement enable
config vlan vlanid 513 add untagged 1-22
enable pvid auto_assign
# IMPBv2
disable address_binding dhcp_snoop ports 1-22,24-28 all
config address_binding ip_mac ports 1-22 arp_inspection strict nd_inspection disable ip_inspection enable protocol ipv4 state enable allow_zeroip enable forward_dhcppkt enable
config address_binding ip_mac ports 23-28 arp_inspection disable nd_inspection disable ip_inspection disable protocol ipv4 state disable allow_zeroip disable forward_dhcppkt enable
config address_binding dhcp_snoop max_entry ports 1-22 limit 5
config address_binding dhcp_snoop max_entry ports 1-28 limit no_limit IPv6
config address_binding dhcp_snoop max_entry ports 23-28 limit no_limit
enable address_binding dhcp_snoop ports 23 all
enable address_binding roaming
config address_binding vlan vlan_mode state disable
config address_binding ip_mac log all
disable address_binding dhcp_pd_snoop
config filter dhcp_server ports 1-22 state enable
config filter dhcp_server illegal_server_log_suppress_duration 5min
# IP
config ipif System state enable
config ipif System ipaddress 172.16.13.80/255.255.128.0
create iproute default 172.16.0.1 1
enable jumbo_frame
config ipif System dhcp_option12 state disable
config ipif System dhcp_option12 hostname DGS-1210-28/ME
config ipif System dhcpv6_client disable
config ipv6 nd ns ipif System retrans_time 1
disable ipif_ipv6_link_local_auto System
config ipif System ipv6 state enable
disable autoconfig
config autoconfig timeout 50
disable autoimage
# STP
enable stp
config stp version rstp
config stp priority 32768 instance_id 0
config stp txholdcount 6 maxage 20 hellotime 2 forwarddelay 15
config stp fbpdu enable
config stp ports 1-22 externalcost 2000000 edge true restricted_tcn true restricted_role true p2p auto state disable priority 128 fbpdu disable
config stp ports 23-28 externalcost auto edge auto restricted_tcn false restricted_role false p2p auto state enable priority 128 fbpdu enable
config stp mst_config_id name 00:12:34:56:78:90 revision_level 0
config stp trap new_root disable
config stp trap topo_change disable
disable address_binding trap_log
# Multi Interface
config ipif System vlan default
# traffic segmentation
config traffic_segmentation 1-28 forward_list 1-28
# LLDP
enable lldp
config lldp message_tx_hold_multiplier 4
config lldp message_tx_interval 30
config lldp reinit_delay 2
config lldp tx_delay 2
config lldp ports 1-28 mgt_addr ipv4 172.16.13.80 disable
config lldp ports 1-22 admin_status disable
config lldp ports 1-22 notification disable
config lldp ports 1-22 basic_tlvs all disable
config lldp ports 1-22 dot1_tlv_pvid disable
config lldp ports 1-22 dot1_tlv_vlan_name vlanid 1-4094 disable
config lldp ports 23-28 admin_status tx_and_rx
config lldp ports 23-28 notification enable
config lldp ports 23-28 basic_tlvs port_description system_name system_description system_capabilities enable
config lldp ports 23-28 dot1_tlv_pvid enable
config lldp ports 23-28 dot1_tlv_vlan_name vlanid 1-4094 enable
config lldp ports 1-22 dot1_tlv_protocol_identity eapol disable
config lldp ports 1-22 dot1_tlv_protocol_identity lacp disable
config lldp ports 1-22 dot1_tlv_protocol_identity gvrp disable
config lldp ports 1-22 dot1_tlv_protocol_identity stp disable
config lldp ports 23-28 dot1_tlv_protocol_identity eapol enable
config lldp ports 23-28 dot1_tlv_protocol_identity lacp enable
config lldp ports 23-28 dot1_tlv_protocol_identity gvrp enable
config lldp ports 23-28 dot1_tlv_protocol_identity stp enable
config lldp ports 1-22 dot3_tlvs all disable
config lldp ports 23-28 dot3_tlvs mac_phy_configuration_status link_aggregation maximum_frame_size enable
# QoS
config scheduling_mechanism strict
config scheduling 0 weight 1
config scheduling 1 weight 2
config scheduling 2 weight 3
config scheduling 3 weight 4
config scheduling 4 weight 5
config scheduling 5 weight 6
config scheduling 6 weight 7
config scheduling 7 weight 8
config 802.1p default_priority 1-28 0
config 802.1p user_priority 0 2
config 802.1p user_priority 1 0
config 802.1p user_priority 2 1
config 802.1p user_priority 3 3
config 802.1p user_priority 4 4
config 802.1p user_priority 5 5
config 802.1p user_priority 6 6
config 802.1p user_priority 7 7
config dscp_mapping dscp_value 0 class 0
config dscp_mapping dscp_value 1 class 0
config dscp_mapping dscp_value 2 class 0
config dscp_mapping dscp_value 3 class 0
config dscp_mapping dscp_value 4 class 0
config dscp_mapping dscp_value 5 class 0
config dscp_mapping dscp_value 6 class 0
config dscp_mapping dscp_value 7 class 0
config dscp_mapping dscp_value 8 class 0
config dscp_mapping dscp_value 9 class 0
config dscp_mapping dscp_value 10 class 0
config dscp_mapping dscp_value 11 class 0
config dscp_mapping dscp_value 12 class 0
config dscp_mapping dscp_value 13 class 0
config dscp_mapping dscp_value 14 class 0
config dscp_mapping dscp_value 15 class 0
config dscp_mapping dscp_value 16 class 0
config dscp_mapping dscp_value 17 class 0
config dscp_mapping dscp_value 18 class 0
config dscp_mapping dscp_value 19 class 0
config dscp_mapping dscp_value 20 class 0
config dscp_mapping dscp_value 21 class 0
config dscp_mapping dscp_value 22 class 0
config dscp_mapping dscp_value 23 class 0
config dscp_mapping dscp_value 24 class 0
config dscp_mapping dscp_value 25 class 0
config dscp_mapping dscp_value 26 class 0
config dscp_mapping dscp_value 27 class 0
config dscp_mapping dscp_value 28 class 0
config dscp_mapping dscp_value 29 class 0
config dscp_mapping dscp_value 30 class 0
config dscp_mapping dscp_value 31 class 0
config dscp_mapping dscp_value 32 class 0
config dscp_mapping dscp_value 33 class 0
config dscp_mapping dscp_value 34 class 0
config dscp_mapping dscp_value 35 class 0
config dscp_mapping dscp_value 36 class 0
config dscp_mapping dscp_value 37 class 0
config dscp_mapping dscp_value 38 class 0
config dscp_mapping dscp_value 39 class 0
config dscp_mapping dscp_value 40 class 0
config dscp_mapping dscp_value 41 class 0
config dscp_mapping dscp_value 42 class 0
config dscp_mapping dscp_value 43 class 0
config dscp_mapping dscp_value 44 class 0
config dscp_mapping dscp_value 45 class 0
config dscp_mapping dscp_value 46 class 0
config dscp_mapping dscp_value 47 class 0
config dscp_mapping dscp_value 48 class 0
config dscp_mapping dscp_value 49 class 0
config dscp_mapping dscp_value 50 class 0
config dscp_mapping dscp_value 51 class 0
config dscp_mapping dscp_value 52 class 0
config dscp_mapping dscp_value 53 class 0
config dscp_mapping dscp_value 54 class 0
config dscp_mapping dscp_value 55 class 0
config dscp_mapping dscp_value 56 class 0
config dscp_mapping dscp_value 57 class 0
config dscp_mapping dscp_value 58 class 0
config dscp_mapping dscp_value 59 class 0
config dscp_mapping dscp_value 60 class 0
config dscp_mapping dscp_value 61 class 0
config dscp_mapping dscp_value 62 class 0
config dscp_mapping dscp_value 63 class 0
config cos mapping port 1-28 none
config cos mapping port 1-28 802.1p
config cos mapping port 1-28 dscp
config cos tos value 0 class 0
config cos tos value 1 class 0
config cos tos value 2 class 0
config cos tos value 3 class 0
config cos tos value 4 class 0
config cos tos value 5 class 0
config cos tos value 6 class 0
config cos tos value 7 class 0
config dscp mode
config bandwidth_control 1-28 rx_rate no_limit tx_rate no_limit
# FDB (forwarding data base)
enable auto learning
# Syslog
disable syslog
config log_save_timing on_demand
# ACL
# SNMP
enable snmp
disable community_encryption
create snmp user ReadOnly ReadOnly v1
create snmp user ReadOnly ReadOnly v2c
create snmp user ReadWrite ReadWrite v1
create snmp user ReadWrite ReadWrite v2c
create snmp group ReadOnly v1 read_view ReadWrite notify_view ReadWrite
create snmp group ReadOnly v2c read_view ReadWrite notify_view ReadWrite
create snmp group ReadWrite v1 read_view ReadWrite write_view ReadWrite notify_view ReadWrite
create snmp group ReadWrite v2c read_view ReadWrite write_view ReadWrite notify_view ReadWrite
create snmp view ReadWrite 1 1 view_type included
create snmp community public ReadOnly
create snmp community private ReadWrite
create snmp host 172.16.0.2 v2c public
config snmp engineID 4447532d313231302d32387062b8960518
disable snmp authenticate traps
config snmp coldstart_traps enable
config snmp warmstart_traps enable
enable snmp linkchange_traps
config snmp linkchange_traps ports 1-28 enable
disable snmp rstpport_state_change traps
enable snmp firmware_upgrade_state traps
enable snmp port_security_violation traps
enable snmp IMPB_violation traps
enable snmp LBD traps
enable snmp DHCP_screening traps
enable snmp duplicate_IP_detected traps
# IPv6 Neighbor_cache
# MAC address table notification
enable mac_notification
config mac_notification interval 1
config mac_notification historysize 1
config mac_notification ports 1-22 enable
config mac_notification ports 23-28 disable
# SNTP
config sntp primary 172.16.0.2 secondary 172.16.0.3 poll-interval 30
enable sntp
config time_zone operator + hour 3 minute 0
config dst annual s_mth 4 s_date 29 s_time 00:00 e_mth 10 e_date 12 e_time 00:00 offset 60
config dst repeat s_mth 4 s_week 1 s_day sun s_time 00:00 e_mth 10 e_week last e_day sun e_time 00:00 offset 60
config dst disable
# DHCP_RELAY
disable dhcp_relay
config dhcp_relay hops 4
config dhcp_relay time 0
config dhcp_relay port 1-28 state disable
config dhcp_relay port 1-28 state enable
config dhcp_relay vlan vlanid 7-8,15,101 state disable
config dhcp_relay vlan vlanid 1 state enable
config dhcp_relay vlan vlanid 513 state disable
config dhcp_relay option_82 state enable
config dhcp_relay option_82 check disable
config dhcp_relay option_82 policy replace
config dhcp_relay option_82 remote_id default
config dhcp_relay option_82 circuit_id default
disable dhcp_local_relay
disable dhcpv6_relay
config dhcpv6_relay hop_count 4
config dhcpv6_relay option_37 state enable
config dhcpv6_relay option_37 check enable
config dhcpv6_relay option_37 remote_id default
config dhcpv6_relay option_38 ports 1-28 state disable subscriber_id default
config dhcpv6_relay option_18 state enable
config dhcpv6_relay option_18 check enable
config dhcpv6_relay option_18 interface_id default
# GVRP
disable gvrp
config gvrp 1-22 pvid 513
config gvrp 1-28 state disable
config gvrp 1-28 ingress_checking enable
config gvrp 1-28 acceptable_frame All_Frames
config gvrp 23-28 pvid 1
config gvrp timer join_timer 200
config gvrp timer leave_timer 600
config gvrp timer leave-all_timer 10000
# Loopback Detection
disable loopdetect
# Power Saving
config power_saving mode led disable
config power_saving led add time_range1 time_range2
config power_saving mode port disable
config power_saving port add time_range1 time_range2
config power_saving mode hibernation disable
config power_saving hibernation add time_range1
config power_saving hibernation add time_range2
config power_saving mode link_detection disable
# BPDU Attack Protection
disable bpdu_protection
config bpdu_protection recovery_timer 60
config bpdu_protection ports 1-28 state disable mode shutdown
config bpdu_protection trap none
config bpdu_protection log none
# SMTP
disable smtp
config smtp server 0.0.0.0 server_port 25
# traffic control
config traffic trap none
config traffic control 1-28 broadcast disable multicast disable unicast disable action drop
# RMON
disable rmon
# ISM vlan
enable igmp_snooping multicast_vlan
create igmp_snooping multicast_vlan "iptv" 8
config igmp_snooping multicast_vlan "iptv" add member_port 1-22
config igmp_snooping multicast_vlan "iptv" add source_port 23-28
config igmp_snooping multicast_vlan "iptv" state enable
config igmp_snooping multicast_vlan "iptv" replace_source_ip 172.18.13.80
config mld_snooping multicast_vlan "iptv" replace_source_ipv6 none
config igmp_snooping multicast_vlan "iptv" remap_priority none
config igmp_snooping multicast_vlan_group "iptv" add ipv4_range 224.0.0.1 224.0.0.2
config igmp_snooping multicast_vlan_group "iptv" add ipv4_range 239.95.0.0 239.195.255.255
# IGMP snooping
config igmp_snooping all router_timeout 125
config igmp_snooping all host_timeout 260
config igmp_snooping data_driven_learning max_learned_entry 256
disable igmp_snooping forward_mcrouter_only
config igmp_snooping vlanid 1,7,15,101,513 state disable fast_leave disable report_suppression enable
config igmp_snooping vlanid 8 state enable fast_leave disable report_suppression enable
config igmp_snooping data_driven_learning vlanid 1,7-8,15,101,513 state disable
config igmp_snooping data_driven_learning vlanid 1,7-8,15,101,513 aged_out disable
config igmp_snooping querier vlanid 1,7-8,15,101,513 state disable querier_version 2 last_member_query_interval 1 max_response_time 10 query_interval 125 robustness_variable 2
config router_ports vlan_name "iptv" add 23-28
config igmp access_authentication ports 1-28 state disable
# MLD Snooping
disable mld_snooping
config mld_snooping all router_timeout 125
config mld_snooping all host_timeout 260
config mld_snooping data_driven_learning max_learned_entry 256
config mld_snooping vlanid 1,7,15,101,513 state disable fast_done disable
config mld_snooping vlanid 8 state enable fast_done disable
config mld_snooping data_driven_learning vlanid 1,7-8,15,101,513 state disable
config mld_snooping querier vlanid 1,7-8,15,101,513 state disable version 2 last_listener_query_interval 1 max_response_time 10 query_interval 125 robustness_variable 2
config mld_snooping mrouter_ports vlan_name "iptv" add 23-28
# Multicast Filter
config multicast vlan_filtering_mode vlan "default" filter_unregistered_groups
config multicast vlan_filtering_mode vlan "test" filter_unregistered_groups
config multicast vlan_filtering_mode vlan "iptv" filter_unregistered_groups
config multicast vlan_filtering_mode vlan "test1" filter_unregistered_groups
config multicast vlan_filtering_mode vlan "test2" filter_unregistered_groups
config multicast vlan_filtering_mode vlan "test3" forward_unregistered_groups
# 8021X
disable 802.1x
config 802.1x auth_mode port_based
config 802.1x auth_protocol local
config 802.1x feap enable
config 802.1x capability ports 1-28 none
config 802.1x auth_parameter ports 1-28 port_control force_auth
config 802.1x auth_parameter ports 1-28 direction both quiet_period 60 tx_period 30 supp_timeout 30 server_timeout 30 max_req 2 reauth_period 3600 enable_reauth disable
# port mirroring
# trusted host
disable trusted_host
# SSL
disable ssl ciphersuite RSA-NULL-MD5 RSA-NULL-SHA1 RSA-DES-SHA1 RSA-3DES-SHA1 DH-RSA-DES-SHA1 DH-RSA-3DES-SHA1 RSA-EXP1024-DES-SHA1
# SSH
disable ssh
config ssh server authfail 2
config ssh server rekey 60min
config ssh server maxsession 4
config ssh server contimeout 120
config ssh authmode password disable
config ssh authmode publickey disable
config ssh authmode hostbased disable
config ssh algorithm 3DES enable
config ssh algorithm MD5 enable
config ssh algorithm SHA1 enable
config ssh algorithm RSA enable
# access authentication control
disable authen_policy
disable aaa_server_password_encryption
config authen parameter response_timeout 30
config authen parameter attempt 3
create authen server_group tacacs+
create authen server_group radius
create authen_login method_list_name default
config authen_login default method local
create authen_enable method_list_name default
config authen_enable default method none
config authen application console login method_list_name default
config authen application telnet login method_list_name default
config authen application ssh login method_list_name default
config authen application http login method_list_name default
config authen application console enable method_list_name default
config authen application telnet enable method_list_name default
config authen application ssh enable method_list_name default
config authen application http enable method_list_name default
# PPPoE
config pppoe circuit_id_insertion state disable
config pppoe circuit_id_insertion ports 1-28 circuit_id ip state disable
config pppoe circuit_id_insertion ports 1-28 remote_id default
# safeguard_engine
config safeguard_engine state enable
disable command logging
# QinQ
config qinq inner_tpid 0x8100
config qinq ports 1-28 role nni missdrop disable outer_tpid 0x8100 add_inner_tag disable
disable qinq
disable vlan_trunk
# Ethernet OAM
config ethernet_oam ports 1-28 state disable mode active remote_loopback stop received_remote_loopback ignore
config ethernet_oam ports 1-28 critical_link_event dying_gasp notify_state enable
config ethernet_oam ports 1-28 critical_link_event critical_event notify_state enable
config ethernet_oam ports 1-28 link_monitor error_symbol threshold 1 window 1000 notify_state enable
config ethernet_oam ports 1-28 link_monitor error_frame threshold 1 window 1000 notify_state enable
config ethernet_oam ports 1-28 link_monitor error_frame_seconds threshold 1 window 60000 notify_state enable
config ethernet_oam ports 1-28 link_monitor error_frame_period threshold 1 window 1488100 notify_state enable
# DULD
config duld ports 1-28 state disable mode normal discovery_time 5
config duld recover_timer 60
# port security
config port_security 1-28 admin_state disable max_learning_addr 0 lock_address_mode DeleteOnTimeout
# LACP
config link_aggregation state disable
config link_aggregation algorithm mac_source
config lacp port_priority 1-28 128 timeout long
config lacp_ports 1-28 mode active
# Limited IP Multicast
config max_mcast_group ports 1-22 ipv4 max_group 5
config max_mcast_group ports 23-28 ipv4 max_group 256
config max_mcast_group ports 1-28 ipv6 max_group 256
config limited_multicast_addr ports 1-28 ipv4 access permit
config limited_multicast_addr ports 1-28 ipv6 access permit
# DoS Prevention
config dos_prevention dos_type land_attack action drop state disable
config dos_prevention dos_type blat_attack action drop state disable
config dos_prevention dos_type tcp_null_scan action drop state disable
config dos_prevention dos_type tcp_xmascan action drop state disable
config dos_prevention dos_type tcp_synfin action drop state disable
config dos_prevention dos_type tcp_syn_srcport_less_1024 action drop state disable
config dos_prevention dos_type ping_death_attack action drop state disable
config dos_prevention dos_type tcp_tiny_frag_attack action drop state disable
disable dos_prevention trap_log
# DDM
config ddm power_unit mw
config ddm ports 25-28 state disable
config ddm ports 25-28 shutdown none
config ddm ports 25-28 temperature_threshold high_alarm +95.000 low_alarm -25.000 high_warning +90.000 low_warning -20.000
config ddm ports 25-28 voltage_threshold high_alarm 3.80 low_alarm 2.80 high_warning 3.70 low_warning 2.90
config ddm ports 25-28 bias_current_threshold high_alarm 20.0 low_alarm 0.5 high_warning 18.0 low_warning 1.0
config ddm ports 25-28 tx_power_threshold high_alarm 1.5900 low_alarm 0.1599 high_warning 1.2599 low_warning 0.2000
config ddm ports 25-28 rx_power_threshold high_alarm 1.2599 low_alarm 0.0099 high_warning 1.0000 low_warning 0.0126
# Flood FDB
disable flood_fdb
# L2 Protocol Tunnel
disable l2protocol_tunnel
# Cpu Protection
disable cpu_protect
config cpu_protect type arp pps no_limit
config cpu_protect type bpdu pps no_limit
config cpu_protect type icmp pps no_limit
config cpu_protect type igmp pps no_limit
config cpu_protect type snmp pps no_limit
# MAC-based VLAN
config mac_based_vlan method single
# Accounting
create accounting method_list_name default
config accounting default method none
config accounting service network state disable
config accounting service shell state disable
config accounting service system state disable
config accounting service command administrator none
config accounting service command operator none
config accounting service command power_user none
config accounting service command user none
# Energy Efficient Ethernet
config EEE port 1 state enable
config EEE port 2 state enable
config EEE port 3 state enable
config EEE port 4 state enable
config EEE port 5 state enable
config EEE port 6 state enable
config EEE port 7 state enable
config EEE port 8 state enable
config EEE port 9 state enable
config EEE port 10 state enable
config EEE port 11 state enable
config EEE port 12 state enable
config EEE port 13 state enable
config EEE port 14 state enable
config EEE port 15 state enable
config EEE port 16 state enable
config EEE port 17 state enable
config EEE port 18 state enable
config EEE port 19 state enable
config EEE port 20 state enable
config EEE port 21 state enable
config EEE port 22 state enable
config EEE port 23 state enable
config EEE port 24 state enable
config EEE port 25 state disable
config EEE port 26 state disable
config EEE port 27 state disable
config EEE port 28 state disable
# port
config ports 1-28 capability_advertised 10_half 10_full 100_half 100_full 1000_full
config ports 1-24 speed auto state enable flow_control disable MDI/MDIX auto learning enable description ""
config ports 25-28 speed auto state enable flow_control disable learning enable description ""
# DDP
enable ddp
config ddp report state enable
config ddp report timer 30
config ddp ports 1 state disable
config ddp ports 2 state disable
config ddp ports 3 state disable
config ddp ports 4 state disable
config ddp ports 5 state disable
config ddp ports 6 state disable
config ddp ports 7 state disable
config ddp ports 8 state disable
config ddp ports 9 state disable
config ddp ports 10 state disable
config ddp ports 11 state disable
config ddp ports 12 state disable
config ddp ports 13 state disable
config ddp ports 14 state disable
config ddp ports 15 state disable
config ddp ports 16 state disable
config ddp ports 17 state disable
config ddp ports 18 state disable
config ddp ports 19 state disable
config ddp ports 20 state disable
config ddp ports 21 state disable
config ddp ports 22 state disable
config ddp ports 23 state enable
config ddp ports 24 state enable
config ddp ports 25 state enable
config ddp ports 26 state enable
config ddp ports 27 state enable
config ddp ports 28 state enable
Соотв. после перезагрузки всё слетает.
Так же в веб-морде не выводится список привязок в Security -> Smart Binding -> Smart Binding. Оттуда можно только новые записи добавить.
В White List нужная запись есть, но нельзя ни очистить ни удалить.
Если записей нет - то запись присутствует в Black List, и после добавления в Smart Binding переходит в White List.
Сами привязки работают как полагается. Разве что не хватает сообщений в логах и трапов.
зы: Никто не подскажет как с него по snmp конфиг на sftp слить?
Забыл: show switch
Command: show switch
Device Type : DGS-1210-28/ME
MAC Address : 70-62-B8-96-05-18
IP Address : 172.16.13.80 (Manual)
VLAN Name : default
Subnet Mask : 255.255.128.0
Default Gateway : 172.16.0.1
System Boot Version : 1.00.013
System Firmware Version : 6.11.B044
System Hardware Version : A1
System Serial Number : S3201E3000954
System Name :
System Location :
System up time : 0 days, 1 hrs, 4 min, 49 secs
System Contact :
System Time : 12/02/2015 19:00:10
STP : Enabled
GVRP : Disabled
IGMP Snooping : Enabled
VLAN Trunk : Disabled
802.1X Status : Disabled
Telnet : Enabled (TCP 23)
Web : Enabled (TCP 80)
RMON : Disabled
SSH : Disabled
Syslog Global State : Disabled
SSL : Disabled
CLI Paging : Enabled
Password Encryption State : Disabled
Размер - величина зависящая от обстоятельств...
Последний раз редактировалось borcat Пт фев 20, 2015 14:24, всего редактировалось 1 раз.
СообщениеДобавлено: Пт фев 13, 2015 15:41
1) Хочется более развернутого вывода по show vlan. Например, как у DES-30XX.
Для сравнения:
DES-3028
DES-3028:5#sh vlan
Command: show vlan
VLAN Trunk State        : Disabled
VLAN Trunk Member Ports :
VID             : 1           VLAN Name       : default
VLAN Type       : Static      Advertisement   : Disabled
Member Ports    : 1-28
Static Ports    : 1-28
Current Tagged Ports   :
Current Untagged Ports : 1-28
Static Tagged Ports    :
Static Untagged Ports  : 1-28
Forbidden Ports        :
DGS-1210-28, 6.11.B044
DGS-1210-28/ME:5# sh vlan
Command: show vlan
VID                : 1        VLAN NAME      : default
VLAN Type          : Static
VLAN Advertisement : Disabled
Member Ports       : 1-28
Forbidden Ports    :
DGS-1210-52, 6.11.B044
DGS-1210-52/ME:5# sh vlan
Command: show vlan
VLAN Type          : Static
Member Ports       : 1-52
Untagged Ports     : 1-52
Forbidden Ports    :
Инфы по тег-портам не выводится. Неудобно.
2) Управление поднимается долго и странно на dgs-1210-52.
Ниже пинг до коммутатора с момента появления в консоли приглашения на ввод логина (т.е., в моем понимании, после полной его загрузки)
Через 1-2 сек. После появления приглашения коммутатор начинает отвечать на запросы.
Но длится это недолго. 3-4 ответа и опять перестает.
Пропадает примерно на 2 мин 20 сек.
Затем начинает отвечать стабильно.
(правда примерно через сутки управление отваливается полностью и до ребута, МАСов на верхних уровнях не видно. С чем связано пока не отловил.)
Превышен интервал ожидания для запроса.
Ответ от 192.168.10.50: число байт=32 время=3мс TTL=57
Ответ от 192.168.10.50: число байт=32 время=8мс TTL=57
Ответ от 192.168.10.50: число байт=32 время=13мс TTL=57
Ответ от 192.168.10.50: число байт=32 время=33мс TTL=57
Ответ от 192.168.10.50: число байт=32 время=15мс TTL=57
Ответ от 192.168.10.50: число байт=32 время=19мс TTL=57
3) Неясности с router_ports. Почему запрещенный 48 порт динамически добавляется несмотря на запрет?
DGS-1210-52/ME:5# show router_ports vlan test
Command: show router_ports vlan test
VLAN Name             : test
Static router port    : 49
Dynamic router port   : 48
Forbidden router port : 1-48,50-52
СообщениеДобавлено: Пт фев 13, 2015 18:49
Если имелось ввиду tftp, то
задаем адрес TFTP-сервера 1.3.6.1.4.1.171.10.76.28.1.3.5.0 a $tftp
задаем путь к конфигу 1.3.6.1.4.1.171.10.76.28.1.3.6.0 s $path
выбираем тип передачи upload 1.3.6.1.4.1.171.10.76.28.1.3.7.0 i 2
СообщениеДобавлено: Пн фев 16, 2015 09:21
IHN спасибо!
Теперь бы с IMB разобраться...
СообщениеДобавлено: Вт фев 17, 2015 13:54
IHN
1. Такова текущая реализация. Возможно, позднее будут изменения.
2. Нужно смотреть конфиг и трафик, который гуляет по управляющему vlan.
3. На стенде не подтверждается. Вы можете привести дампы igmp пакетов, которые вызывают такое поведение?
СообщениеДобавлено: Ср фев 18, 2015 18:57
Pimv2 hello на 224.0.0.13
СообщениеДобавлено: Чт фев 19, 2015 13:44
Опять же не подтверждается.
Пришлите, пожалуйста, ваш конфиг и дамп пакета в формате pcap.
СообщениеДобавлено: Пт фев 20, 2015 11:48
DGS-1210-52, 6.11.B044, конфиг в дефолте, секция #Basic
выслал лс
СообщениеДобавлено: Пт фев 20, 2015 12:28
Видимо, это какие-то другие пакеты, потому что после скармливания коммутатору присланных вами пакетов с вашим же конфигом, forbidden порты не изучаются как router.
Проблема не подтверждается.
P.S. коммутатор DGS-1210-52/ME, FW 6.11.B045
СообщениеДобавлено: Пт фев 20, 2015 14:23
Так что про работу с IMB? http://forum.dlink.ru/viewtopic.php?f=2&t=165874&p=923086#p922723
СообщениеДобавлено: Вт фев 24, 2015 11:49
Прошился на 6.11.B045 - проблема исчезла.
СообщениеДобавлено: Ср фев 25, 2015 11:27
Несколько дней назад обновился до 6.11.B045
Вчера проводил реорганизацию сети.
Конфиг:
# Vlan
create vlan "VLAN0002" tag 2
create vlan "VLAN0003" tag 3
create vlan "WiFi-test" tag 4
create vlan "WiFi-staff" tag 5
create vlan "VLAN0032" tag 32
create vlan "Staff" tag 42
create vlan "Classrooms" tag 43
create vlan "VLAN0100" tag 100
config vlan vlanid 1-5,32,42-43,100 delete 1-28
config vlan vlanid 1 add tagged 25-28
config vlan vlanid 1 add untagged 1
config vlan vlanid 1-5,32,42-43,100 advertisement enable
config vlan vlanid 2-5,100 add tagged 3-5
config vlan vlanid 32 add untagged 2,6-8
config vlan vlanid 42 add untagged 9-18
config vlan vlanid 43 add untagged 19-24
# IP
config ipif System ipaddress 192.168.200.118/255.255.255.0
create iproute default 192.168.200.2 1
disable jumbo_frame
enable ipif_ipv6_link_local_auto System
disable autoconfig
disable autoimage
# QinQ
disable qinq
enable vlan_trunk
config vlan_trunk ports 25-28 state enable
Столкнулся с интересной вещью.
После импорта трафик по вланам не идёт по транку с DGS-3120.
В то время как DGS-1510 работают без проблем.
Методом тыка нашёл, что если вручную создавать вланы, то трафик по ним идёт.
Но опять же только две-три штуки подряд.
Если завести сразу все, то не работают.
Ресетил их неоднократно, прошивал обратно на B044 и вроде на B040 (уже точно не помню).
Как такое может быть?
СообщениеДобавлено: Ср фев 25, 2015 12:10
Начиная где-то с B35 (точно не уверен), заведённые на 1210 вланы нужно заранее вручную добавлять к транковым портам.
Завожу сразу все, работают нормально. По крайней мере, после перезагрузки.
СообщениеДобавлено: Ср фев 25, 2015 21:28
Доброго времени суток может у кого-то наблюдается тоже самое - коммутатор DGS-1210-28/ME, FW 6.11.B045 самопроизвольная перезагрузка раз в сутки может и через двое суток в логах только это
ID Time Log Description Severity
3 Feb 25 20:16:16 Successful login through Web ( IP: 10.10.10.155 ) info
2 Feb 25 19:39:49 System started up critical
1 Jan 1 00:00:04 Management IP address was changed. New IP: 10.10.10.98 info
Может это брак?
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 82
