Текущее время: Ср мар 04, 2026 00:20
 Заголовок сообщения: DNS 320 BETA firmwarev2.02b01
СообщениеДобавлено: Чт сен 29, 2011 13:04
вчера перепрошил, работает ок. (установка на ваш риск!) ftp://ftp.dlink.com/Multimedia/dns320/Beta/
v2.02b01 Release Date - 09/01/2011 - сентябрь :D
1. [New Feature] Support 3TB Disk.
2. [Bug Fix] Apple Finder failed to browse file through Samba issue.
3. [New Feature] Support Amazon S3 Cloud Backup.
4. [Bug Fix]Support WD My Book Essential 2TB USB 2.0.
5. [Bug Fix]P2P shared folder able to invisible via FTP.
6. [Bug Fix]"Blocking unauthorized login of nobody, root and etc special users".
7. [Change]Block Raid Migration from DNS-323 (causing corrupted data).
8. [New Feature] Support WebDAV.
9. [New Feature] WebDAV support Open Mode.
10. [Bug Fix] System time will be +1 hour after restart.
11. [Bug Fix] If you apply a Samba share to FTP service, you are no way to disable it individually besides deleting the whole share from "Network Share".
12. [Bug Fix] Print server does not work when custom shares are configured
13. [Bug Fix] Workgroup Name is to restrictive and does not allow legitament characters
14. [Bug fix] Fan non-stopping issue.
15. [Bug fix] Cannot copy files bigger than 200MB to USB drive.
16. [Bug Fix]External Drive with NTFS partiton support Read/Write.
17. [New Feature] Time Machine fails to work on Mac OS X 10.7 Lion issue.
18. [New Feature] Support Samsung D2 version Nand Flash.
19. [Bug Fix] System Time drift issue.
20. [Bug Fix] FTP backup issue with 722/726.
21. [Bug Fix] Support IE9.
если необходимо вернутся на базовую прошивку необходимо держать ресет больше 6 секунд, а также сохр. конфигурацию для посл. загрузки. вчера прогнал скорость по 100-ке сетке около 8-12 МБ на диск форм. RAID0, и 1.7-2.2 на JBOD, еще болшьше инфо на http://forums.dlink.com/index.php?board=276.0
