Текущее время: Ср июн 26, 2019 12:11
 Заголовок сообщения: DGS-3100-24TG непрерывная перезагрузка
СообщениеДобавлено: Вт июн 19, 2012 18:59
Добрый день,
Есть сабж, который отлично работал. В одно прекрасное утро начал постоянно перегружаться
Выдает по кругу:
------ Performing the Power-On Self Test (POST) ------
UART Channel Loopback Test........................PASS
Testing the System SDRAM..........................PASS
Boot1 Checksum Test...............................PASS
Boot2 Checksum Test...............................PASS
Flash Image Validation Test.......................PASS
BOOT Software Version 1.0.1.05 Built  13-Oct-2009  15:37:32
MAC Address   :  00:21:91:ХХ:ХХ:ХХ.
Preparing to decompress...
 100%
Decompressing SW from image-1
 100%
OK
Running from RAM...
*** Running  SW  Ver. 3.60.26  Date  15-Mar-2010  Time  23:34:15 ***
Serial Number :  F3Q3189ХХХХХХ.
HW version is: 04
Base Mac address is: 00:21:91:ХХ:ХХ:ХХ
Dram size is: 64M bytes
Flash size is: 16M bytes
01-Jan-2000 01:01:08 %CDB-I-LOADCONFIG: Loading running configuration.
01-Jan-2000 01:01:08 %CDB-I-LOADCONFIG: Loading startup configuration.
Device configuration:
Slot 1 - DGS-3100-24TG ST
-- Unit Factory Default           --
01-Jan-2000 01:01:21 %Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration change trap.
01-Jan-2000 01:01:39 %INIT-I-InitCompleted: Initialization task is completed
>To perform reset to factory defaults do not release the button for 5 seconds.
-- Unit Number 1  Master Enabled --
Tapi Version: v1.3.3.1
Core Version: v1.3.3.1
01-Jan-2000 01:01:41 %SNMP-I-CDBITEMSNUM: Number of running configuration items loaded: 0
01-Jan-2000 01:01:41 %SNMP-I-CDBITEMSNUM: Number of startup configuration items loaded: 0
>01-Jan-2000 01:01:42 %Stack-I-STCK-CFG-CHNG: Configuration changed: chain
lcli
UserName:
Deleting auto update backup file...OK
Deleting auto update instruction file...OK
resetting local unit
*****************  SYSTEM RESET  *****************
Можно успеть набрать
show configuration startup
ответ:
DGS-3100# 01-Jan-2000 01:01:43 %LINK-W-Down:  1:1
!         DGS-3100-24TG  Gigabit stackable L2 Managed Switch
!                            Configuration
!                       Firmware: Build 3.60.26
!     Copyright(C) 2008 D-Link Corporation. All rights reserved.
! BASIC
! SNMP
disable snmp
create snmp community ******* view DefaultSuper read_write
create snmp community ****** view Default read_only
! AUTHENTICATION
! NETWORK MONITORING
! LINK AGGREGATION
! PORT
! VLAN
! FORWARDING TABLE
! BROADCAST STORM CONTROL
! PORT MIRRORING
! QOS
! MULTIPLE SPANNING TREE
! IGMP SNOOPING
! 802.1X
! SNTP
! SSH
! SSL
! BASIC IP
01-Jan-2000 01:01:47
HOSTP_flash_verify error: offset 0x881aec - data 0xff instead of 0x61.
HOSTP_flash_operation: fatal error during erase operation!
HOSTP_flash_verify error: offset 0x881b25 - data 0x43 instead of 0x53.
HOSTP_flash_verify error: offset 0x881b38 - data 0x50 instead of 0x54.
%SYSLOG-F-OSFATAL:
HOSTP_flash_verify error: offset 0x881b40 - data 0x60 instead of 0x61.
HOSTP_flash_verify error: offset 0x881b78 - data 0x0 instead of 0x52.
HOSTP_flash_verify error: offset 0x881b8f - data 0x0 instead of 0x57.
RSFLEG_read: failed 1
HOSTP_flash_verify error: offset 0x881b97 - data 0x0 instead of 0x61.
HOSTP_flash_verify error: offset 0x881bcf - data 0x5 instead of 0xd.
HOSTP_flash_verify error: offset 0x881bec - data 0x0 instead of 0x5d.
***** FATAL ERROR *****
HOSTP_flash_verify error: offset 0x881bf5 - data 0x30 instead of 0x33.
HOSTP_flash_verify error: offset 0x881c2c - data 0x10 instead of 0x52.
HOSTP_flash_verify error: offset 0x881c82 - data 0x0 instead of 0x96.
Reporting Task: SNMP.
Software Version: 3.60.26 (date  15-Mar-2010 time  23:34:15)
HOSTP_flash_verify error: offset 0x881c8a - data 0x60 instead of 0x61.
HOSTP_flash_verify error: offset 0x881cc2 - data 0x0 instead of 0x30.
HOSTP_flash_verify error: offset 0x881ccd - data 0x0 instead of 0x4b.
0x144724
HOSTP_flash_verify error: offset 0x881cd5 - data 0x60 instead of 0x61.
HOSTP_flash_verify error: offset 0x881d0d - data 0x0 instead of 0x30.
HOSTP_flash_verify error: offset 0x881d18 - data 0x0 instead of 0x4b.
0x141d0c
HOSTP_flash_verify error: offset 0x881d20 - data 0x60 instead of 0x61.
HOSTP_flash_verify error: offset 0x881d58 - data 0x0 instead of 0x30.
HOSTP_flash_verify error: offset 0x881d63 - data 0x0 instead of 0x4b.
0x545050
HOSTP_flash_verify error: offset 0x881d6b - data 0x60 instead of 0x61.
HOSTP_flash_verify error: offset 0x881da3 - data 0x0 instead of 0x30.
HOSTP_flash_verify error: offset 0x881dae - data 0x0 instead of 0x4b.
0x4a2018
HOSTP_flash_verify error: offset 0x881db6 - data 0x60 instead of 0x61.
HOSTP_flash_verify error: offset 0x881dee - data 0x0 instead of 0x30.
HOSTP_flash_verify error: offset 0x881df9 - data 0x0 instead of 0x4b.
0x36158c
HOSTP_flash_verify error: offset 0x881e01 - data 0x60 instead of 0x61.
HOSTP_flash_verify error: offset 0x881e39 - data 0x0 instead of 0x30.
HOSTP_flash_verify error: offset 0x881e44 - data 0x0 instead of 0x4b.
0x361838
HOSTP_flash_verify error: offset 0x881e4c - data 0x60 instead of 0x61.
HOSTP_flash_verify error: offset 0x881e84 - data 0x0 instead of 0x30.
HOSTP_flash_verify error: offset 0x881e8f - data 0x0 instead of 0x4b.
0x4c2708
HOSTP_flash_verify error: offset 0x881e97 - data 0x60 instead of 0x61.
HOSTP_flash_verify error: offset 0x881ecf - data 0x0 instead of 0x30.
HOSTP_flash_verify error: offset 0x881eda - data 0x0 instead of 0x4b.
0x365d00
HOSTP_flash_verify error: offset 0x881ee2 - data 0x60 instead of 0x61.
HOSTP_flash_verify error: offset 0x881f1a - data 0x0 instead of 0x30.
HOSTP_flash_verify error: offset 0x881f25 - data 0x0 instead of 0x4b.
0x3609ec
HOSTP_flash_verify error: offset 0x881f2d - data 0x60 instead of 0x61.
HOSTP_flash_verify error: offset 0x881f65 - data 0x0 instead of 0x30.
HOSTP_flash_verify error: offset 0x881f70 - data 0x0 instead of 0x4b.
0x3408a0
HOSTP_flash_verify error: offset 0x881f78 - data 0x60 instead of 0x61.
HOSTP_flash_verify error: offset 0x881fb0 - data 0x0 instead of 0x30.
HOSTP_flash_verify error: offset 0x881fbb - data 0x0 instead of 0x4b.
0x34f328
HOSTP_flash_verify error: offset 0x881fc3 - data 0x60 instead of 0x61.
HOSTP_flash_verify error: offset 0x881ffb - data 0x0 instead of 0x30.
HOSTP_flash_verify error: offset 0x882006 - data 0x0 instead of 0x4b.
0x351164
HOSTP_flash_verify error: offset 0x88200e - data 0x60 instead of 0x61.
HOSTP_flash_verify error: offset 0x882046 - data 0x0 instead of 0x30.
HOSTP_flash_verify error: offset 0x882051 - data 0x0 instead of 0x4b.
0x338eec
HOSTP_flash_verify error: offset 0x882059 - data 0x60 instead of 0x61.
HOSTP_flash_verify error: offset 0x882091 - data 0x0 instead of 0x30.
HOSTP_flash_verify error: offset 0x88209c - data 0x0 instead of 0x4b.
0x4b324c
Похоже на ошибки в флеш в области сохранения конфигурации.
Возможно как-то исправить без сервиса? Команды ввести могу, но перезагружаеться сразу после ввода через 3 секунды.
Спасибо.
СообщениеДобавлено: Вт июн 19, 2012 20:55
Вентиляторы менять пытались? Девайс "считает", что нажата кнопка RESET
СообщениеДобавлено: Ср июн 20, 2012 10:48
У меня тоже сначала сложилось такое-же представление,но такой кнопки нету, "официально".
Да, вентиляторы менялись на неродные (лампочка Fan Err моргала), но после замены все работало некоторое время. Проверяли шлейфы, которые ведут к дисплейчику с цифрами и кнопкой, та-же история если их отключить, кнопка вроде не нажата.
СообщениеДобавлено: Ср июн 20, 2012 19:19
Есть кнопка, есть... Только дырки нету над ней. :))
Если вентиляторы менялись, как некоторые особо "умные" товарищЧи умудряются делать, "на ходу", то - приехали, теперь только в сервис - LCMXO640 сдохла. :(
СообщениеДобавлено: Ср июн 20, 2012 19:39
Спасибо большое за ответ, теперь ясно что к чему. Странно что нет защиты от дурака.
Кстати некоторое время все работало ОК после замены, возможно просто слишком большой ток вентиляторов, ведь они не родные, или что-то того.
СообщениеДобавлено: Ср июн 20, 2012 20:27
Дело не в токе потребления вентиляторов, хотя теперь уже без разницы...
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 1
